load contral arms
Old Feb 25, 2006 | 04:38 PM
tricky's Avatar
Default load contral arms
my load control arms need to be replaced....what will happen if l don't replace them... i dont want to replace them....cost to much
Old Feb 25, 2006 | 04:44 PM
Jestnomen's Avatar
6th Gear
Default RE: load contral arms
Are you talking about the upper or lower control arms? Never heard them called "load control arms". Get them fixed you don't want them to fail.
Old Feb 25, 2006 | 05:19 PM
tricky's Avatar
upper and lower....what will happen if they fail
Old Feb 25, 2006 | 07:45 PM
brewmastr's Avatar
if the ball joint in them fails and comes seperated from any one of the control arms=your audi wrecked on the side of the road and a really pist of you! Replace your control arms, http://www.blauparts.com has a good deal on the kits right now.
Old Feb 25, 2006 | 09:05 PM
Jestnomen's Avatar
6th Gear
Bad things will happen. Think a guy here or on Audiworld had one fail and his wheel ripped off and did extensive damage.
Old Feb 25, 2006 | 09:13 PM
techbod's Avatar
Default RE: load control arms
http://images.google.co.uk/images?sv...=+control+arms
a grave is only 6ft deep but permanent
Old Feb 26, 2006 | 01:16 AM
sandman's Avatar
ORIGINAL: Jestnomen
hahaaha, i remember reading about this.
get ur car to the dealer you may be able to have them replaced for free. lower control arms were a recall item on earlier model a4s
Old Feb 26, 2006 | 02:19 AM
j_ripper19's Avatar
Hey everyone,
How much mileage can you get with new control arms (upper and lower)? Or it's an unsteady thing and can be anytime?
Thanks
Old Feb 26, 2006 | 02:25 AM
Jestnomen's Avatar
6th Gear
Yep you can't really predict it. Usually they start to fail around 70k miles though?
Old Feb 26, 2006 | 02:33 AM
j_ripper19's Avatar
Then how do you check them? Can you diagnose them properly or do you only tell by the noise when you steer?
