LOL at getting chipped for $500
ORIGINAL: tooxtreme8813
i'm not bad mouthing speedtuning im bad mouthing thier custmer service...its pretty bad when you refuse to offer someone a free reflash
So as an example - if you replace your dirty stockair filter with a new K&N, expecting a 5 HP gain, and you have a bad MAF, your car will still run like **** - but it's not the fault of the new filter, it's still the MAF. So blame the air filter anyway.
Brian, no point in getting my car dyno-ed, unless it's free. I don't need to pay to know i got my hp/$ worth, and then some. Plus no point in dyno-ing until I do my BT/BT tune/FMIC/injectors/clutch.... probably this summer.
Hmm lets see what did I pay for 20+ lbs of boost. 150 for speed tuning + 80 forge 006. The grand total comes to 230. You paid 770 more dollars hmm thats 298% more than I spent. And You dont feel like a dumbass.
ORIGINAL: A4speed
8lb of boost, -20 hg vac... come on...
i know there are plenty of happy speedtuning customers such as yourself, but you have to say with those readings and no CEL or flashing CEL (im assuming so because i don't believe hes mentioned it) it was the flash that didn't go correctly. speedtuning should atleast re-flash it on the simple fact that his car seems to, well... be stock
~20 in Hg does indicate there's probably no vacuum leak, but itcan not indicate the turbo is up to par or not. Turbos do occassionally STB too.
STB = **** the bed
Here's another example from auditurbo381:
https://www.audiforums.com/m_755108/mpage_1/key_/tm.htm
Maybe the car won't start b/c of the speedtuning ecu....but he had no fuel getting to the cylinders.
I'd like to know what finallyhappened to that one? Fuel pump, fuse, relay, or speedtuning flash to blame?
ORIGINAL: Rhinop21
whats that, and i don't have to ship my ecu away and have it come back the same, really? I only have to pay $25 to reflash and not the full price again if something terribly goes wrong, I have people i can talk to face to face, wow.
listen bud, i would pay extra just to make sure my car is how its suppose to be. Mailing my ecu to a not to know company here in the states to have them flash my ecu cheaper but nothing happening is kind of a problem... if it happened to you, you would be the one sh*tting your pants.
ORIGINAL: Bogie
ORIGINAL: Bogie
Well, I'd first like to hear the other half of the story, and I'd also like to know this dude's qualifications for being able to diag the prob as the ecu. Maybe the ecu had a problem with it (ecus do occassionally STB) and this whole thing is a coincidence.
STB = **** the bed
ORIGINAL: A4speed
STB = **** the bed
maybe it's a 99.5 issue. here's another 99.5 guy with a GIAC tuning problem earlier today:
https://www.audiforums.com/m_784469/tm.htm
