Looking for the cruise control module
Old Jan 17, 2008 | 06:45 PM
auditech79's Avatar
Default RE: Looking for the cruise control module
OOPS! Never mind, i found the answer though, you don't have the module on a throttle by wire equipped car. Stupid ELSA WEB doesn't seem to care what year car you have. [:@]LOOK>
Cruise Control System, 4- and 6-Cylinder Engines
Caution[/align]
Disconnect the battery Ground (GND) strap before working on the electrical system.
Note[/align]
t
Before disconnecting the battery, determine the correct coding for the anti-theft radio.
t
Once the battery is reconnected, check and activate the vehicle's electrical equipment (radio, clock, comfort and convenience features, etc.) as outlined in this Repair Manual or the Owners Manual.
Electronically-Operated Throttle Valve
In vehicles with fuel injection, the functions of the cruise control system are controlled by the fuel injection control module.
Aside from the cruise control switch in the turn signal lever, there are no additional components.
Mechanically-Operated Throttle Valve
The cruise control, control module -J213- is located behind the airbag unit on the passenger side.
Old Jan 17, 2008 | 06:56 PM
acollicott's Avatar
Alright now i dont feel like such a dumb a$$. i was hoping to diagnose the module so i didnt have to take off the airbag, but it looks like thats where im headed to now. Thanks for the help auditech79
Old Jan 17, 2008 | 07:17 PM
auditech79's Avatar
Whats wrong with your cruise control anyway?
Old Jan 17, 2008 | 07:52 PM
acollicott's Avatar
When i bought the car a couple of weeks ago the cc worked and then over night a few days ago it just stopped working completely. I think the problem is probably in the stalk, but I was reading the DIY and it said to try this first.
Old Jan 17, 2008 | 07:56 PM
auditech79's Avatar
Yeah its probably the stalk, if thats not it its the ECM, but thats doubtfull.
You should double check the vaccum lines to make sure you don't have a leak either, if there isn't sufficient vaccum the cruise control won't work.
Old Jan 18, 2008 | 01:00 AM
acollicott's Avatar
Alright thanks I'll try that tommorow
carpeme
Aug 27, 2009 07:12 AM
carpeme
Aug 20, 2009 10:53 AM
neomaxddr
Mar 5, 2009 09:24 PM
m6amba
Sep 10, 2008 01:04 PM
JDriver2
Jul 10, 2006 11:16 PM
