Looks like it's new turbo time......
Old Jan 6, 2007 | 07:29 PM
K1196A's Avatar
Default Looks like it's new turbo time......
Took the car to the stealership today to have them determine why my acceleration was so shitty and to get the oil changed. Long story short, I had a boost leak that they repaired and it runs WAYYY better now. Here is the down side, when doing the oil they noticed some leaks around the engine block and diagnosed them the valve cover gasket and the cam adjustment gasket. Worse yet, the tech said the turbo is spitting oil! They want $2230 to do all that, which I'm sure I can get done cheaper elsewhere.
So, my car is a 99.5 A4 1.8TQA with a GIAC chip on the engine and transmission, high flow cat and Borla exhaust -- should I just go ahead and put a K04 kit on it? What sort of additional expenses should I expect? Is it basically a simple plug-n-play or will I be expecting major complications?
Also, anybody familiar with a good shop in the Harrisburg, PA area? AWE does great work in Philly, but they aren't exactly cheap. Where is the best place to get a K04 kit?
Old Jan 6, 2007 | 07:34 PM
onepoint8tee's Avatar
Default RE: Looks like it's new turbo time......
Get a 2nd oppinion.
Old Jan 6, 2007 | 10:32 PM
K1196A's Avatar
I'll definately do that, but let's assume that the turbo is bad for the sake of discussion and for the sake of me starting to figure out which kidney I can let go!
Old Jan 6, 2007 | 10:55 PM
Turbulence's Avatar
ko4 fits right on....
i think finding one may be the harder part to it tho, from what i hear is those things are always backed up orderwise...
Old Jan 6, 2007 | 10:57 PM
Turbulence's Avatar
check this thread out as well, might help..
https://www.audiforums.com/m_401446/tm.htm
MRKoo
Apr 2, 2008 12:14 PM
SilverAudiS4
Nov 27, 2007 07:48 PM
lidonnit
Jul 28, 2005 10:42 AM
King_D
Nov 25, 2004 09:17 PM
