Losing Turbo Pressure... please help
Old Jun 22, 2006 | 05:02 AM
ranzor's Avatar
Default Losing Turbo Pressure... please help
Hi!
I would need som help whit my new Audi A4 1.8 Turbo Quattro -96.
I have changed the turbo to a Mitsubichi TD04-15t, but when i put the
pedal to the flor i lose the turbo pressure the i get some then i lose it
again. So it don't keep the pressure. It's all the time when i try to put
the pedal to the metal.
(It's onely the turbo pressure that dissepers the car keeps on acelrate but the turbo goes on and off every second)
It's not the lmm, ignition cords, fuelpump. Anyone know what the problem
can be?
Please help me...
Tanx...
best of regards
Jörgen
Sweden
(hope you understand my bad english)
Old Jun 22, 2006 | 05:21 AM
BadLuckAudi's Avatar
Default RE: Losing Turbo Pressure... please help
might be a bad diverter valve
Old Jun 22, 2006 | 09:04 AM
david9999's Avatar
It could also be a bad wastegate. I am not familiar with this turbo. If you change your turbo, you will most likely need new programming and fuel mapping otherwise the turbo will not run correctly as the Engine control module can't understand what is going on and tires to compensate.
Old Jun 22, 2006 | 08:32 PM
gearup's Avatar
need an suitable remapping
b5quattrodiesel
Jun 4, 2015 03:57 PM
rsvmike
Jun 5, 2008 07:44 AM
cbrstu
May 13, 2006 10:15 PM
acetrebo
May 4, 2006 12:52 PM
