Loud Groaning When Turning Wheels
Old Nov 3, 2013 | 06:12 PM
rubenemmitt's Avatar
Default Loud Groaning When Turning Wheels
My big brother in Afghanistan just sent me his 2000 Audi A4. As it's been sitting for over 2 years, I have a feeling I'll be spending a lot of time on here getting answers and advice!
I've driven it for a week, and now all of a sudden there is a REALLY loud groan when I turn the steering wheel the slightest bit. The Power Steering fluid level is fine. What should I look for next? Is it still OK to drive while having things checked?
Old Nov 4, 2013 | 09:02 AM
M5S5's Avatar
Tech Certified
If your fluid is full , check the connections of the power steering suction side. There is a good chance there is air leaking past the hoses & clamps!
Does the fluid look like there is a lot of bubbles when running?
Old Nov 4, 2013 | 12:55 PM
Thanks. While I am trying to check that out, is it ok to drive the car to work? Or should it not be driven at all until this is resolved?
Old Nov 5, 2013 | 10:03 AM
rhodes991's Avatar
If for some reason fluid is not getting into the system I would not drive it. You could damage the steering system. Also, note that Audi requires a certain type of power steering fluid and if the wrong fluid is used it will create problems.
Old Nov 7, 2013 | 10:09 AM
M5S5's Avatar
Tech Certified
You will need CHF-11S for the steering system. It would probably be best if you can get it repaired as soon as possible.
DewAudiA4
Oct 2, 2012 07:36 PM
a6_driver
Feb 27, 2011 10:56 AM
Inimical
Sep 23, 2009 06:13 PM
mra
Oct 27, 2007 10:35 PM
