LOW OIL (PSI)
Old Jan 10, 2008 | 11:12 AM
Dj Spiel's Avatar
Default LOW OIL (PSI)
My gauge is indicating low PSI levels...ideas?
No Leaks that I can find
No Puddles of Oil
Car= 1999.5 1.8TQM
132,000 MILES
thanks in advanced!
Old Jan 10, 2008 | 12:29 PM
kendalll's Avatar
Default RE: LOW OIL (PSI)
what oil are you running? if you're running 5w-30 you could switch to 5w-40 you'd get a bump in pressure if you're lowing pressure due to increased tolerances in your wearings and what not.
Old Jan 10, 2008 | 01:38 PM
Dj Spiel's Avatar
0W-30
Old Jan 10, 2008 | 01:39 PM
Dj Spiel's Avatar
ENGINE MODS
GIAC
E-Code TestPipe
Borla V1
Stock k03
710N DV
Old Jan 10, 2008 | 02:02 PM
SLVR99A4's Avatar
Even though recommended you probably would not want to read the post further down related to Oil sludge...
Old Jan 10, 2008 | 02:07 PM
Dj Spiel's Avatar
https://www.audiforums.com/m_8602/tm.htm
(Yeah my friend I should move to something thicker, I will do that)
Keep u guys posted
Old Jan 10, 2008 | 02:23 PM
chaos92287's Avatar
yeah switch to 0w-40 and see if that helps. but before you do, you might as well seafoam it if you haven't done it before or if it hasn't been done for ~50k
Old Jan 10, 2008 | 02:28 PM
CRAZYHAWK's Avatar
Put 1 1/2 oz of Seafoam for every quart of oil, and change the oil
in 50 mi. I'm using Mobil 110W-40 High Mileage.
