Lowering.??
Old Mar 9, 2005 | 10:02 PM
Covz's Avatar
Default Lowering.??
I have 19's and i am looking into lowering it alittle. i dont want to lower it to much to where u cant see the upper part of the wheel b/c the wheel well is covering it, i want it to look clean, like an even space between the wheel and the wheel-well al the way around.. do u recomend .5in 1in or 1.5in..???? and what manufacturer of springs?
Old Mar 9, 2005 | 10:05 PM
CheckMyVitals's Avatar
Default RE: Lowering.??
i'd only go .5 with 19s you're probably almost tucking as is. even with a .5 drop, you're probably gonna be doing som trimming and rolling to avoid rubbing. i wouldn't suggest suspension mod... i also wouldn't have suggested 19s...
Old Mar 9, 2005 | 10:06 PM
Jestnomen's Avatar
6th Gear
Might want to get coilovers so you aren't stuck with a certain hight. Might be helpful in winter time.
Old Mar 10, 2005 | 03:07 AM
ImolaS4's Avatar
Ditto what they both said, but Jestnomen's advice is best.
Old Mar 10, 2005 | 03:10 AM
04a4's Avatar
there was this guy featured on Eurotuner awhile back that put 3piece 20's on his A4 with a 1.5" drop.... so don't worry about it. do the 1.5" roll the fenders and get the 19's
Old Mar 10, 2005 | 03:21 AM
ImolaS4's Avatar
ORIGINAL: 04a4
Yeah.. but there was no mention of the drop in suspension performance and the rubbing that occur at speed.
Old Mar 10, 2005 | 03:23 AM
04a4's Avatar
true, but when you lower there's always that bump that you will rub on.
Old Mar 10, 2005 | 03:32 AM
ImolaS4's Avatar
What I mean is that there is a point where performance begins to suffer well beyond the gain in aesthetics. At some point each driver/owner is going to realize that the "look" doesn't offset the lack of drivability.
Old Mar 10, 2005 | 03:33 AM
04a4's Avatar
yeah i see your point
djnick
Dec 12, 2009 11:07 PM
mikeeace
Dec 1, 2009 12:02 PM
petes4
Mar 9, 2008 08:51 PM
100mhz
Jun 21, 2007 12:57 PM
mark80scu
Apr 13, 2007 08:07 PM
