Lowering a 99' A4?
Old Jun 29, 2007 | 12:44 PM
Johnmax's Avatar
Default Lowering a 99' A4?
How much can I lower a 1999 A4 if i get 19's on 225/35/19 tires? Would i be able to lower it 1.25 or would i have to go with 18's?
Old Jun 29, 2007 | 12:46 PM
Lazer Viking's Avatar
Default RE: Lowering a 99' A4?
go with 18"s either way.. unless you like bending rims and driving carefully
and get coilovers, that way you can adjust it to the height you like
Old Jun 29, 2007 | 12:53 PM
Johnmax's Avatar
So how much of a drop could I do with 18's?
Old Jun 29, 2007 | 06:43 PM
CTown's Avatar
1.25 should be fine with 18s. You don't have to get coilovers unless you got the money for them (they are gonna run you an extra 3-400 over just buying springs and struts). I just dropped my car 1.25 and it is the perfect drop I think, the car looks great on the stock rims.
Old Jun 29, 2007 | 06:53 PM
coberst's Avatar
ORIGINAL: CTown
I agree. the stock audi rims are so nice.
Old Jun 29, 2007 | 08:16 PM
MasterV's Avatar
I have 18's with the voghtland sport springs which drop it 1.5 and it looks really good for a car with just springs.
Old Jun 29, 2007 | 11:34 PM
headshok2002's Avatar
The diameter of the wheel doesn't have a bearing on how low you can go... you can go just as low on 20's as you can on 16's.
Width is what matters... and offset. I'm 24" from the ground to the fender, running 225/40/18 on an 8.5" wheel. If I were running 225/35/19's... I'd have the exact same sized tire (outer dimensions) so it wouldn't make any difference. Same goes for 225/30/20's.
djnick
Dec 12, 2009 11:07 PM
mikeeace
Dec 1, 2009 12:02 PM
petes4
Mar 9, 2008 08:51 PM
100mhz
Jun 21, 2007 12:57 PM
mark80scu
Apr 13, 2007 08:07 PM
