lowering my a4
Old Dec 5, 2004 | 12:24 AM
brogenville's Avatar
Default lowering my a4
Given that Im on a pretty tight budget (student and all), do you guys thinks that I would get away with putting lowering springs in and not changing the stock shockers? Or will the shocks just die soon after? Im more into changing the look of the car, so I dont intend on throwing it about too often.
Any guidlines on which springs are good? Ive a 98 2.4 v6 tip.
Cheers again.
Old Dec 5, 2004 | 01:14 AM
David_K's Avatar
Default RE: lowering my a4
Since your not looking for a stiff ride but just lowering look into Eibach. they make lowering springs that have a softer ride then other companies. on the issue of shocks. mismatched shocks and springs will cause a really uncomfortable ride. i would go to www.tirerack.com they have a Eibach setup that includes springs and shocks. i thnk its like 5 or 6 hundred dollars. Which is a standard price for springs and shocks. they also make a pro plus kit that include anti-roll bars. but these are not needed since you arent doing any type of organized racing.
Old Dec 5, 2004 | 01:17 AM
Jestnomen's Avatar
6th Gear
your factory shocks are not meant to be lowered. They will end up dying soon after, and then you'll have to replace them and pay for a second alignment.
Old Dec 5, 2004 | 01:19 AM
David_K's Avatar
Hey, i learned something new today.
If you dont want to buy the shocks that come with that kit. companies lke koni and others have adjustable shocks
Old Dec 5, 2004 | 04:55 AM
SlimChriz's Avatar
I got koni ajustibles
Old Dec 5, 2004 | 05:07 AM
PandaXpress's Avatar
wont u start to butterfly errr .... i mean camber if u change your springs wit out a camber kit
Old Dec 5, 2004 | 10:53 AM
dont think so, not if you have your new set up aligned properly.
Old Dec 5, 2004 | 07:27 PM
David_K's Avatar
yeah an alignment takes care of that.
Old Dec 6, 2004 | 02:39 AM
Jestnomen's Avatar
6th Gear
You don't need a camber kit unless you go REALLY REALLY low.
Old Dec 6, 2004 | 03:01 AM
David_K's Avatar
or you want to play around with your alignment for Autox events.
