MAP clamping...??
Old Sep 17, 2007 | 09:55 PM
kemp_travis's Avatar
Default MAP clamping...??
ive searched and searched....but i cant find out what "clamping the MAP sensor" actually does....and is it possible on my car? i have heard that you can increase boost with an MBC PAST 1BAR without a chip, and without going into limp mode...is this even possible?...is it possible with a bigger FPR??
im quite confused if it is possible to raise boost past the 14.7 psi without a chip and without limp mode, b/c now if i spike over 14.7 with my current MBC it "limps out"...help me out im very confused on the MAP clamp and wht it is, and on boost raising...
thanks guys
Old Sep 17, 2007 | 09:56 PM
cincyTT's Avatar
I'm make believe
Default RE: MAP clamping...??
That means using a diode and we have covered this
/thread
Old Sep 17, 2007 | 10:22 PM
oh....i thought it was 2 different things....so that means nothin for me then...correct?
Old Sep 17, 2007 | 10:23 PM
cincyTT's Avatar
I'm make believe
Correct
/THREAD
Old Sep 17, 2007 | 10:43 PM
onepoint8tee's Avatar
You already knew you didnt have a map sensor, because 73 people told you so in your other cluster **** thread. We already told you what you needed to do to safely and effectively raise your boost. Are you ok?
Old Sep 17, 2007 | 10:44 PM
TeeterTawter's Avatar
I want what hes on
Old Sep 17, 2007 | 10:54 PM
Audi_Skydiver's Avatar
No you don't, it makes you a stupid POS kid who asks the same question over and over and threadjacks. You don't want to be that guy now do you?
That was harsh... [&:]
Josh
Old Sep 17, 2007 | 10:59 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: cincyTT
/THREAD
Old Sep 17, 2007 | 11:01 PM
Goodbye.
mrdavies
Aug 14, 2008 05:56 PM
edmhess
May 10, 2008 11:02 PM
audibri02
Jan 23, 2007 11:39 PM
