Mass Air Flow Sensor-Help
Old Apr 29, 2006 | 08:54 AM
tuga.A4's Avatar
Default Mass Air Flow Sensor-Help
Hello everyone,
i owned a audi A4 19tdi from 2001, does anyone have an installation schematic or something walks me through the installation ,
can someone help,
Old Apr 29, 2006 | 12:54 PM
CRAZYHAWK's Avatar
Default RE: Mass Air Flow Sensor-Help
Check Audiworld
Old Apr 29, 2006 | 01:20 PM
techbod's Avatar
its in the air filter box
Old Apr 29, 2006 | 01:25 PM
techbod's Avatar
scratches head "why would you need to change that then" what codes have you got to rquire such an act??
Old Apr 30, 2006 | 05:25 AM
tuga.A4's Avatar
Thanks,
Old Apr 30, 2006 | 05:27 AM
tuga.A4's Avatar
for the moment i didn't check the codes, I had a loss of power and everyone is telling me that the problem is the Air Flow sensor, do you have a different opinion,
Old Apr 30, 2006 | 05:28 AM
BadLuckAudi's Avatar
there are many many reasons for power loss what are your symptoms
Old Apr 30, 2006 | 07:18 AM
techbod's Avatar
have the codes checked, the MAF is blamed for many things when it could be down to an air leak/spark plus/bad fuel its common to blame the MAF because its expensive to replace but just changing it without checking properly is a bad way to fix problems you will end up changing this unnecessarily
Old Apr 30, 2006 | 11:19 PM
sdaudi's Avatar
also, the MAF is covered under warranty for 7 years/70k miles. you should get a CEL code if the MAF sensor is busted. in that case, if you're still under the warranty limit, take it to a dealer becasue the MAF is expensive to replace.
Old Jan 9, 2013 | 06:35 AM
wanar8's Avatar
Default flat spot
hi guys am new to this site hope you can help have an allroad 2.7 03 about 70.000 km has developed a bad flat spot as though it running out of fuel between 1500 and about 3000 has no throttle response at all but if you can pick the revs up it will then rev out with no problem but on light throttle cruising it pretty poor no previous indications has never missed a beat i m suspecting the air mass meter dose any one have any other suggestions also can i ask can you read fault codes from the car by with out a reader thanks not sure if this is the correct way to post a question but couldn't see any were to submit new thred
steve
Gypsy Man
Jul 23, 2011 02:51 PM
LKaler
Apr 26, 2010 09:43 PM
abedel2
Feb 7, 2010 07:57 PM
Nick_UltraSport
Feb 9, 2009 10:49 PM
fromerich
Nov 10, 2006 10:05 PM
