MBC... How ito run it with the N75 valve..
Old Mar 19, 2007 | 07:21 PM
Bondga's Avatar
Default RE: MBC... How ito run it with the N75 valve..
Ohhh. I c
Old Mar 19, 2007 | 08:21 PM
JohnnyBravoA4's Avatar
well thats a great idea in therory, but I used three different kinds of MBC's and everyone of them creaped.. two of the three creeped so the boost went up on creep down.. they like everything else is not perfect.. I would personally want to keep the N75 valve as a fail safe.. you have to leave it pluged in anyway or you wont get any boost past 5psi or 6psi whatever the factory setting is at the wastegate
ORIGINAL: Jeff
well just run the mbc not the n75. set the boost at what ever your tuning calls for and leave it
Old Mar 19, 2007 | 08:34 PM
Jeff's Avatar
Zombie Defense Force
what kind of mbc were you using? and boost creep can be cuased by more then a mbc
Old Mar 20, 2007 | 01:12 AM
when i say creep i ment to say the MBC *** would turn itself from the vibration of the engine, I used two different turbo xs MBC's and i forgot the brand i ended up sticking with..
Old Mar 20, 2007 | 01:36 AM
Jeff's Avatar
o what get the forge unos and it will not move at all. it takes effort to turn it. i promis it wont move on you
Old Mar 20, 2007 | 10:50 AM
dont need one anymore.. Im thinking on getting an EBC so when i switch back and forth between programs i can lock in a pis range... when i have it in the low boost setting on my apr chip i go into limp mode once in a while because it over bosts..
ORIGINAL: Jeff
Old Mar 20, 2007 | 01:16 PM
MissionCtrl's Avatar
did your mbc's have a little screw to tighten up to lock it in place? my turbosmart one does...that SOB ain't goin nowhere unless I want it to.
Old Mar 20, 2007 | 03:25 PM
  #18
the three I bought didnt.. all were 50-80 bucks each
Old Mar 20, 2007 | 05:55 PM
  #19
mine was only like 80 bucks cdn...pretty cheap.
Old Mar 20, 2007 | 06:04 PM
  #20
Jeff's Avatar
ya good call on the ebc. im getting one so i can run high boost with alky injection on the track or for spirited drives and low boost with out alky for mpg. i think im getting the greddy one
