mbc install.........please help.
Old Feb 13, 2006 | 11:21 PM
black991.8tq's Avatar
Default mbc install.........please help.
well i got all new vac lines today and installed my samco tip. but i still only get around 8psi with my mbc???? any help would be great. if u need more info on my car just ask. thanks.
Old Feb 13, 2006 | 11:44 PM
Jeff's Avatar
Zombie Defense Force
Default RE: mbc install.........please help.
u may have a hole in ur diaphram. how is ur mbc hooked up? with the n75?
Old Feb 14, 2006 | 12:12 AM
diafram??? my mbc is hooked up by itself, but i left the n75 plugged in. its a forge mbc with the 3 prongs and its hooked up wit the bottom one going into the tip, one going from turbo and 1 going to wastegate.
Old Feb 14, 2006 | 12:25 AM
Jeff's Avatar
ORIGINAL: black991.8tq
what tip?
Old Feb 14, 2006 | 12:27 AM
turbo intake pipe
Old Feb 14, 2006 | 12:30 AM
Jeff's Avatar
y do u have one going from the turbo intake pipe?
i would do it turbo---mbc---wastegate thats all u need
Old Feb 14, 2006 | 12:40 AM
yea but my mbc is a forge and it has 3 prongs and its supposed to go into the turbo intake pipe. i dunno its a POS
Old Feb 14, 2006 | 12:46 AM
Jeff's Avatar
just that third one out and plug that hole, also make sure that u have all the vaccuum lines going the right way into the mbc
Old Feb 14, 2006 | 03:16 AM
i tried that then plugged in the stock n75 and i am only getting about 10 psi??????? i dunno whats wrong......could it be the new hoses that i put on???? dose anyone know the correct hose size?
Old Feb 14, 2006 | 05:14 PM
quattrosedan's Avatar
ok...here is what you do...
one hose goes into wastegate.
one hose goes to intake manifold.
one hose goes to n75 valve.
That is how my mbc was hooked up on the gt28r. It was a pos from ebay and it worked.
