Metal rattle sound on Steep Inclines/Warmup
Old Sep 27, 2007 | 11:18 PM
what?'s Avatar
Default Metal rattle sound on Steep Inclines/Warmup
So this only happens later in the day, not on cold start ups in the morning. At work I park in a under ground garage, and when I go to leave I hear a not overly loud but not quite quiet metal clank/rattle sound when in gear and giving the car gas. It gets louder as I hit the ramp (which is steep) at low rpm's, then goes away when the car fully warms up. It reminds me of the sound I had back when my old Integra had a crack in its heatshield, except less high pitch.
Im wondering if its my transmission...hope not...I always did kind of think my transmission was loud, especially just slowly rolling and shifting into 1st/sitting a shifting threw gears always sounds clunky. Any idea's?
ps...saw an r8 today rolling through La Jolla during my lunch break. I was like wtf is that!? Then saw the rings and was like "wow damn". Btw la jolla for those that don't know is home to people with $$ see 650i's and sl500's all day etc.
Old Sep 28, 2007 | 07:38 AM
oneg's Avatar
Default RE: Metal rattle sound on Steep Inclines/Warmup
well theres alot of things that could be making a little rattaling noise. from cats too a loose..anything? One thing i can tell you is that you can probably hear it only in the garage because your in a more enclosed place, but the noise is happening all the time. I would check for vissable things first. other wise im not sure. someone elese might know?[&:]
Old Sep 28, 2007 | 08:56 AM
hiwords's Avatar
does it do it when u rev the engine or only when ur going? check ur belt and pulleys, see if u can wiggle the exhaust pipe under ur car, and bang on ur cat conv with ur fist.
Old Sep 28, 2007 | 09:17 AM
The Bishop's Avatar
If it goes away when the car warms up, it's probably some sort of exhaust leak. I know. I had one too.
Old Sep 28, 2007 | 01:26 PM
jinnyboo's Avatar
i get this too, especially when i hit around 5,000 rpm. it just starts ratteling like crazy then it goes away as i let off the gas.
Old Sep 28, 2007 | 03:03 PM
The Bishop's Avatar
Or a loose wastegate flap.
Old Sep 28, 2007 | 10:29 PM
what?'s Avatar
It sounds like the sound of metal vibrating against metal...but who knows. Its very metallic and menacing sounding.
It only happens when I'm around 1000 or lower (clutch working or clutch out). Then when going up the ramp with the clutch completely disengaged it still makes the sounds, it sounds a bit scarry like my maybe my clutch is struggling up the hill ?
I'll get under my car and bang the cat around tomorrow, thanks for the tips I'll check back in later.
Wheres the wastegate on this car? The sound seems to come from under the car...but its in a garage so..
dbestn
Dec 20, 2013 04:10 PM
westhive4life
Sep 17, 2013 01:34 PM
Keith Kessler
Feb 19, 2012 08:50 AM
austindgarner
Apr 23, 2010 05:38 PM
yemenmocha
Aug 31, 2007 12:12 AM
