rattle sound help!!
Old Dec 13, 2013 | 06:01 PM
dbestn's Avatar
Default rattle sound help!!
so let me start off with the car..... its a 04 a4 1.8t . the problem started when i noticed a vibration sound inside the car. once you step outside it is defiantly noticeable but its not as loud as it seems from inside the car. inside it sounds like metal vibrating against metal. it seems to be from the rear and it happens even when im in park which leads me to believe its exhaust related . sometimes when my foot is not on the gas im just moving along it goes away but once i get back on it starts up again . it seems like once the car gets "hot" after like a half hour of driving it goes away , only coming back in very short spurs. now i cant really fit my head under my car because its an ultrasport but im just looking for ideas as to what i should look for and what it could possibly be .
Old Dec 14, 2013 | 09:49 AM
dbestn's Avatar
update..... seems to be a pump looking component on the passenger side. the vibration is either coming from it or just above it.
Old Dec 18, 2013 | 10:24 PM
Coors's Avatar
I am experiencing a similar noise also in my 04 Ultrasport. Seems to be coming from rear passenger section. The car sits so damn low I can't see under it.
I thought it was a wheel bearing starting to dry up cause it shares similar humming/rubbing notes, but the noise is there at idle too.
What pump ? Fuel pump? Isn't that under the rear passenger seat/trunk area like the B5S4's?
Old Dec 19, 2013 | 03:48 PM
Coors's Avatar
Anyone know what would cause this? Today the sound got obnoxiously louder. The whole rear section of the car vibrates at idle. It sounds like a pump is vibrating sending shock waves thorough the car.
What pumps are located rear passenger by the gas tank??
Old Dec 19, 2013 | 03:55 PM
Coors's Avatar
Well. This is an active forum...
It's gotta be the fuel filter/pump. I'm replacing the filter first to see if that rectifies the problem. If not I guess the pump is next. I'll report back with my findings.
Old Dec 19, 2013 | 06:05 PM
Coors's Avatar
...on the side of road waiting for tow truck. Fuel pump took a crap.
dbestn, I suggest you address the problem ASAP. Otherwise you'll also be roadside in the near future searching frantically for that "emergency beer" while waiting for the hook to come to the rescue.
Old Dec 20, 2013 | 04:08 PM
02A4kid's Avatar
if its coming from the passenger side rear (usually by the seats on the bottom of the car) its the fuel filter. if it gets really clogged it can cause the pump to die because the load is increased. the pump is on top of the tank itself, there is a small access panel you take off and you can see the pump easily. about a 10-15 minute DIY
Old Dec 20, 2013 | 04:10 PM
02A4kid's Avatar
Christopher Nemitz
Oct 15, 2012 10:00 AM
rob1
Jul 2, 2009 11:48 PM
B5ecosse
Jul 13, 2008 06:29 PM
what?
Sep 28, 2007 10:29 PM
CBing
Apr 30, 2005 07:56 PM
