Mini digital boost gauge install
Old Oct 21, 2004 | 11:38 PM
blades's Avatar
Member
Default Mini digital boost gauge install
Well, this isn't exactly a true "boost gauge", but it's a pressure switch used on automation equipment that happens to have a nice digital pressure (and vacuum) readout. Found it at work.
It's a small cube-shaped housing. I had an aluminum "U" shaped bracket made to hold it in place against a piece of tinted lexan that is used for the faceplate. The faceplate fits snugly into place where in 2 of the 3 vacant switchs. It's not very dark tinted, which is why you can see behind it with the help of the camera flash. This pic isn't very flattering, it looks better in person. I really wish it were a red LED display, but can't complain for the price. It's easily readable day or night.
Old Oct 22, 2004 | 01:05 AM
99a4audi's Avatar
Default RE: Mini digital boost gauge install
thats looks sweet, creative
Old Oct 22, 2004 | 05:03 AM
David_K's Avatar
here take out the lexas and paint the back black. it will keep you from being able to see behind it. this is what i did with my switches. ill post a pic asap.
Old Oct 22, 2004 | 10:47 AM
blades's Avatar
Member
99a4audi, thanks. D_K, exellent idea! Will do that this weekend.
Old Oct 22, 2004 | 06:17 PM
Transverse's Avatar
Is it a backlit display? If so you should get a black peice of plastic to stick over the top to make it flush with the rest of the console.
-T
Old Oct 22, 2004 | 07:23 PM
brrman's Avatar
getout the bondo and make youself a small front panel for that sucker. Then it would look friggin cool.
Old Oct 23, 2004 | 12:32 AM
blades's Avatar
Member
I may make a new faceplate out of aluminum, either polished or brushed finish. Might look better.
Old Oct 25, 2004 | 01:15 PM
David_K's Avatar
not unless the rest of your dash is aluminum
B5wilkes1992
Feb 25, 2014 10:05 AM
Arkma
Oct 26, 2011 03:23 PM
bam_bam
Aug 3, 2007 07:14 PM
MC Hammered
Jan 13, 2007 10:47 PM
Peteman187
May 16, 2005 03:46 AM
