Installing Digital Boost Gauge
Old Feb 21, 2014 | 02:50 PM
B5wilkes1992's Avatar
Default Installing Digital Boost Gauge
Hey guys, does anyone have a video or picture diagram of a boost gauge install onto the pillar? There are a few diagrams and videos of easy ways to install the vent gauge but not other ways. Help Please
1999 Audi A4 1.8t (non quattro)
Old Feb 22, 2014 | 12:52 PM
A4TurboGuy's Avatar
I'd love to see a DIY on this!
Old Feb 22, 2014 | 01:19 PM
Pbcrazy's Avatar
The problem with a pillar mount is that a lot of b5s have an airbag right there. Should the airbag deploy, you will have a boostguage come right at you face; and besides, IMO they look much better in the vents (I have 2 gauges, one on either side of the steering wheel in vents). But if you don't have an airbag, I believe you just need to remove that cover, drill a hole, and the screw the pod on
Old Feb 23, 2014 | 07:40 AM
A4TurboGuy's Avatar
I figured that (which is why I don't have one yet).
Do you have or, know of a writeup on the vent pods? I don't understand how you're running the vacuum & electrical line through the vent ducting.
Old Feb 24, 2014 | 11:45 AM
swimbikerunrun's Avatar
Not sure if you're interested but there's a youtube video that shows the lag difference between digital and mechanical gauges.. quite interesting, afterwards I ended up buying a mechanical.
Old Feb 24, 2014 | 03:23 PM
Pbcrazy's Avatar
I don't know of any DIY's but it's very simple to do, you just run the tubing through the ecu box, down under the steering wheel, then into the air duct with a small hole you puncture in the side. Then the wiring goes through the same hole, into the fuse box where you hook it up to the fuel pump to run all the time or the license plate lights to only run at night. At least that's how I did mine
Old Feb 24, 2014 | 03:26 PM
I found a decent diagram and installed it saturday. Took a little while, about an hour and a 1/2. (had to go back to autozone for some extra clamps and tubing). Wiring was pretty easy. I don't have an airbag in the pillar, so I installed the pillar mount with some double sided tape and screws. It looks great. I'll post some pics soon.
Thanks for the responses
Old Feb 25, 2014 | 10:05 AM
A4TurboGuy's Avatar
Thanks!
Arkma
Oct 26, 2011 03:23 PM
bam_bam
Aug 3, 2007 07:14 PM
MC Hammered
Jan 13, 2007 10:47 PM
Peteman187
May 16, 2005 03:46 AM
blades
Oct 25, 2004 01:15 PM
