misfire!
Old Dec 11, 2007 | 12:25 AM
quattro Teufel's Avatar
Default misfire!
my 1998 A4 Quattro is misfiring like crazy right after i just replaced the wires and plugs
i know it has nothing to do with the valve cover gaskets i put in, cause that was 2 weeks ago and it was fine since then
someone help me figure out what is wrong
it sounds like my cats are gonna blow up and i have to drive to work everyday, i don't want to blow my engine, so i need help asap
Old Dec 11, 2007 | 12:30 AM
Default RE: misfire!
o and check engine light is blinking!
and its the 2.8 if that will matter
Old Dec 11, 2007 | 04:32 AM
ucla86's Avatar
ORIGINAL: quattro Teufel
Check the codes:
https://www.audiforums.com/m_565488/tm.htm
I don't know squat about the 2.8, but it's probably:
A. 1 (or more) wires are not secure. Re-seat 'em.
B. 2 or more wires got crossed and now go to the wrong cylinder. Replacing the wires one at a time is usually the best way to prevent this.
C. Are you sure the store gave you the right plugs/wires?
Old Dec 11, 2007 | 07:33 AM
khj677turbo's Avatar
Get it fixed asap, i was having some problems and ended up bending a valve. I know 1.8t isnt the same, but i think you have a good guess as to what your problem is, take the time get it fixed.
Old Dec 11, 2007 | 10:41 AM
i re-seated them 10 times, checking to make sure i didn't crack a plug or anything
i did all of it one at a time, cause i know im not an expert but the order is obvious anyhow
4-5-6
3-2-1 < am i right?
where can i find the proper order to run them?
Old Dec 11, 2007 | 02:44 PM
brightside06's Avatar
if you look on your coil packs it shows a mini diagram what one goes to what cylinder. the cylinders are numbered on the valve cover right next to the spark plug holes.
Old Dec 11, 2007 | 02:56 PM
techbod's Avatar
6-5-4
3-2-1
Old Dec 11, 2007 | 02:57 PM
techbod's Avatar
4 and 1 are front of engine near radiator
Old Dec 11, 2007 | 11:33 PM
i figured out why i got confused
my coil pack goes left to right, while everyone elses goes up and down with the engine
all better, lights off and all
Old Dec 11, 2007 | 11:37 PM
i wonder why that is.... did the previous owner preplace it with an aftermarket one?
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
