misfire!
my 1998 A4 Quattro is misfiring like crazy right after i just replaced the wires and plugs
i know it has nothing to do with the valve cover gaskets i put in, cause that was 2 weeks ago and it was fine since then
someone help me figure out what is wrong
it sounds like my cats are gonna blow up and i have to drive to work everyday, i don't want to blow my engine, so i need help asap
ORIGINAL: quattro Teufel
o and check engine light is blinking!
https://www.audiforums.com/m_565488/tm.htm
I don't know squat about the 2.8, but it's probably:
A. 1 (or more) wires are not secure. Re-seat 'em.
B. 2 or more wires got crossed and now go to the wrong cylinder. Replacing the wires one at a time is usually the best way to prevent this.
C. Are you sure the store gave you the right plugs/wires?
i re-seated them 10 times, checking to make sure i didn't crack a plug or anything
i did all of it one at a time, cause i know im not an expert but the order is obvious anyhow
4-5-6
3-2-1 < am i right?
where can i find the proper order to run them?
4-5-6
3-2-1 < am i right?
Russ Heinrichs
Aug 18, 2021 12:39 PM
A4ENGRSF
Oct 9, 2010 09:49 PM
