Misfire misfire misfire!!!!
Old Jan 10, 2007 | 01:18 PM
JohnnyBravoA4's Avatar
Default Misfire misfire misfire!!!!
ran some logs, cant post them wish i knew how, i dont have a camera right now, if someone wants to post it for me i will send it to them through email but other then that im beat, getting misfires in cly 2 and cly 3 not at the same time but they bolth happen in high RPM at high boosts.. any thoughts? might need to pick up some new coil packs but it could be a spark plug issue not sure..
Old Jan 10, 2007 | 02:05 PM
John DeLuca's Avatar
Default RE: Misfire misfire misfire!!!!
I had misfires at highboostthe day after I reflashed my A4. I popped in the new coilpacks Audi just released and havent had a problem since. Also, you may want to check out ECS tuning paste below.
ECS Stage I Ignition solution converts your troublesome & hard to get Bremi brand coil packs (oem part # 06B 905 115L or R) with the more durable Hitachi brand coil pack. Over the years the Hitachi has shown to be much more durable than the Bremi's along with being able to be secured to the valve cover with 2 allen headed bolts. This ECS stage I ignition solution kit includes the following:
[ul][*]Four OEM "E" version Hitachi coil packs[*]8 OEM securing screws[*]OEM wiring harness heat sheild[*]4 NGK spark plugs (PFR6Q) [/ul][/align]
Old Jan 10, 2007 | 02:12 PM
i cant run the 4 NGK spark plugs (PFR6Q) becasue im BT.. think they are to cool enough.. but that might be a thought thanks.. im going to try the musical coil pack trick and see if the misfire moves.. then buy coil packs..
Old Jan 10, 2007 | 02:58 PM
http://home.comcast.net/~existential/images/Johnny.CSV
here is my log file.. if someone wants to post it up that would be great as it is now someone on one of my other fourms set it up for me.. but you need to save it or open it
Russ Heinrichs
Aug 18, 2021 12:39 PM
dorkfish
May 6, 2013 09:58 AM
slow_key
Sep 23, 2010 08:25 AM
themahr
Mar 31, 2009 03:50 PM
