Miss fire occatinally
Old Sep 12, 2006 | 12:41 PM
catchnsk's Avatar
Default Miss fire occatinally
I have a 98 a4 2.8 and Since it ran 100K miles I replaced all my 6 spark plugs... and also I did a fuel injector cleaning.
After two weeks .. I find a jerk motion very occatinally and also my engine check light started glowing. Since I though it could be a miss fire .
I took it for a scan. But it did not so me any code. The mechanic said that.. he found the miss fire very occationaly. and in the scan he did not fine any code.
Does one have any suggestions ?
Old Sep 12, 2006 | 07:33 PM
i3uddha's Avatar
Site Moderator/Ninja
Default RE: Miss fire occatinally
hmmm maybe coilpacks?
Old Sep 13, 2006 | 01:31 AM
david9999's Avatar
Could be pack, ignition module, fuel injector, plugged fuel filter, bad gap on a spark plug. Lots of things. Since it started after you replaced your spark plugs, I'd go back and check the spark plug gaps and make sure that the wire connections are tight.
If you had a check engine light, there should have been a code stored in there.
rajien2
Apr 16, 2015 10:37 PM
wesley7883
Jul 18, 2014 08:00 PM
06A42.0TUt
Dec 14, 2012 06:42 PM
onepoint8tee
Dec 13, 2006 10:33 PM
hugoagogo
Sep 9, 2006 10:38 AM
