miss firing an maf codes
Old Mar 1, 2012 | 12:37 PM
A4shoe's Avatar
Default miss firing an maf codes
I have misfiring all cylinders an a maf codes. The car has a rough idle it goes up an down from 8 to 12 an some time it will rev to 20. I don't have power loss the car seems fine. It dose jerk or buck sometimes in first gear. Need help plez. On a 2000 a4 1.8t quttro
Old Mar 1, 2012 | 05:16 PM
M5S5's Avatar
Tech Certified
A bad mass air flow sensor can cause misfire codes. Good idea to replace mass air flow sensor , reset faults & see what happens.
Old Mar 1, 2012 | 05:41 PM
A4shoe's Avatar
OK now the car will not run it just died an you turn it on runs for a sec then dies still think it is a mass
Old Mar 1, 2012 | 06:30 PM
M5S5's Avatar
Tech Certified
Try disconnecting the mass & see what happens.
Old Mar 1, 2012 | 09:05 PM
A4shoe's Avatar
OK i have pulled it all out cleaned it an let it sit we will see what happens
rickyates100
S8
Apr 23, 2015 03:43 PM
Dclem
May 3, 2014 01:11 PM
LinziB75
Jan 15, 2010 04:15 PM
lgbyblock
Sep 10, 2006 06:15 PM
