More DAMN problems
alrite theres more problems wit my damn car
more head ached but thank god this one is a easy fixer
but there are still more problems
PROBLEM 1
can anyone i dentify the problem
well heres a hint, i cant believe i missed it
PROBLEM 2
and my brakes are ****** up
for some weird reason the brake pedal wont stay up
it slumps down like 1cm and it activated the brake light
it does this randonly, my brake lights were for a whole night
I DONT WANT TO ****** GET A NEW BATTERY AGAIN
i just got a new one like a week or 2 ago
im getting everything checked on monday again along wit a new O2 sensor
PROBLEM 3
this is a bad one, this is giving me a big head ache
my turbo is cutting off randomly
even after the hose replacimg
i gotta see wuts up, i hope nuthin major
PROBLEM 1
PROBLEM 2
PROBLEM 3
ORIGINAL: headshok2002
haha that hose is the EXACT one that I fixed! Good luck with all the rest... let us know how you make out!
Take the panel that is the roof of the driver's footwell off, get your head down there. There is a little white button that touches the metal arm that the brake pedal is attatched to. I cannot remember if pushing this button or lifting the arm off it causes the brake light to come on. So you'll have to check for youself. I'm pretty sure the light comes on when the arm isn't touching the button, because the way I fixed my problem, and it sounds like the exact same one you're having, is by gluing a really thin foam piece about the size of a dime on the end of the button to make it contact the pedal arm again to make the brake lights come off when the pedal isn't depressed. I fucked mine up when I was drilling holes for my AWE pedals and pulled the pedal too far forward. You'll have to mess around with it.
I don't even know if your problem is the same as mine. If you can pull your pedal up to where it normally rests, and the brake lights come off, then try my solution. If not, I don't know, but I'm sorry for not helping you.
ORIGINAL: Yuikio
ORIGINAL: PandaXpress
i think i'll look in to it rite now
ORIGINAL: Yuikio
I know VW has problems with the brake light switch in there cars. Its just a replacement part.
