More rev hanging.
Old Dec 31, 2005 | 05:30 AM
blackflame's Avatar
Default More rev hanging.
I am the new owner of a B5 Audi A4 1.8t Quattro. Whenever I shift I get some pretty hardcore rev hanging. I know how to shift and I have even tried letting off the gas and pushing in the clutch a second later just to make sure and it still just hangs for second. Spirited driving is the worse. Its pretty annoying especially when try to hit second and it hangs at 5K through out the shift. Does anybody else have this problem. How would you fix it.
Old Dec 31, 2005 | 05:50 AM
trailboss's Avatar
Default RE: More rev hanging.
Well if the rev's hang its normal from what i can tell in your explanation. Our cars have 25lb duall mass flywheels that keep the revs hanging. The rev's will drop, but not fast.
Old Dec 31, 2005 | 06:04 AM
blackflame's Avatar
I was thinking its the flywheel since I read how much they weigh. It does seem normal, I am just not use to it is all. So I guess a lightweight flywheel is going in with a new clutch when the time comes. Any recommendations.
Old Dec 31, 2005 | 06:14 AM
trailboss's Avatar
Overall southbend and unorthadox lwfw go pretty well, you will get chatter since you are going to a single mass aluminum flywheel. The AWE clutch kits are the same the use the unorthadox lwfw but call it Aasco. WOA clutch with their 15lb single mass steel flywheel doesn't chatter much at all from what i read and that is the route im going, they are a bit pricey though. Spec also makes clutches but alot of people have complained about the chatter with a lwfw.
BT5150
Mar 17, 2011 09:14 PM
Gigantor
May 27, 2009 08:12 AM
Lefty
Jul 18, 2008 10:05 AM
hypnotiks
Mar 15, 2005 10:04 PM
