Motor Mounts
Old Feb 27, 2007 | 04:34 AM
rward011's Avatar
Default Motor Mounts
So, I have an exhaust leak at the flexpipe but the shop won't do the warranty work because my motor mounts have gone bad. If I install the APR snub mount....do you think that will do the trick or should I just go ahead and invest in a couple of RS4 motor mounts????
Old Feb 27, 2007 | 04:57 AM
sean1.8t's Avatar
Default RE: Motor Mounts
i don't know what "gone bad" means.. but if they are shot then, NO, the snub mount will not do the trick. get new mounts..
and don't get the overpriced APR snub mount.. just get a greedspeed mount for like $20 shipped..
Old Feb 27, 2007 | 05:15 AM
A4Rollin's Avatar
i 2nd that
Old Feb 27, 2007 | 11:37 AM
david9999's Avatar
Why don't you replace the flex pipe. It is cheap.
Old Feb 27, 2007 | 12:39 PM
oh1a4's Avatar
puremotorsports snub is great. many people have to shave the apr snub to reduce vibration. 034 makes the best replacement imho.
for engine mounts use 2.8/s4 8D0199379K ($50 ea)
while you are there, do your tranny mounts:
passenger rs4 8Do399151T $43
driver stock 1.8t 8D0399151H $41
Old Feb 27, 2007 | 12:51 PM
sirfalconx's Avatar
I love my RS4 mounts, it fixed the jerking/vibrations I had from the stock shitty ones. Deff worth the investment.
Old Feb 27, 2007 | 03:12 PM
rward011's Avatar
yah thats what I was expecting to hear.....I've already replaced the flex pipe once and since the motor mounts are bad it has cause the flex pipe to crack again
Old Feb 27, 2007 | 06:31 PM
Mike@PureMS's Avatar
A snub mount is not a replacement for worn motor mounts. If you have worn motor mounts, replace them.
Old Feb 27, 2007 | 06:35 PM
Lazer Viking's Avatar
yea... rs4 motor mounts for sure
but while you are in there.. greedspeed snub
Nemick
Sep 17, 2012 06:34 PM
murdox
Aug 24, 2011 10:06 AM
guru_king423
Apr 7, 2009 10:48 PM
SouthernAudi
Feb 9, 2008 07:48 PM
jimmyt853
Jan 12, 2007 02:22 AM
