Motor ticking
Old May 25, 2007 | 03:00 PM
Quattro_1.8t's Avatar
Default Motor ticking
I just got my test pipe installed today. When I started driving my car I did not hear any ticking. About 2 minutes into driving the car my engine started ticking only under heavy acceleration. If I barely use the gas you can barely hear it. If im not under any load sitting somewhere and just free rev the car you cannot hear any ticking. Before when I had the catalytic converter on, my engine would tick until the car was warmed up a bit. It did not tick when free revving though. I was told it could be valve lifters but im not sure. Any ideas?
Old May 25, 2007 | 03:03 PM
ironman's Avatar
Default RE: Motor ticking
check the oil and make sure all teh conenctions are soiund and bring it back to who did it they made hacve screwed something up.
Old May 25, 2007 | 03:13 PM
Oil is good, the connections look fine
Old May 25, 2007 | 03:17 PM
techbod's Avatar
could be serious and called pinking this is when fuel/air mix is wrong and mostly happens when engine is under load, when doing mods you have to consider the fuel rating and in most cases this is where the problem is from.
use higher octane and see if the noise goes ( failure to stop it will burn your valves out )
Old May 25, 2007 | 03:22 PM
ironman's Avatar
You may be getting some sludging bring it in to the dealer, adn have them check it could be the beginning of the end of the for your engine
Old May 25, 2007 | 03:23 PM
I have always used 93 octane (Shell V-Power) so I don't think thats the problem
AteUrV8's Avatar
is it in all gears?? or only first??
Old May 25, 2007 | 03:27 PM
techbod's Avatar
I have always used 93 octane and that's where it begins ( you modded your engine right ) so try higher octane
Old May 25, 2007 | 03:29 PM
engine is stock except test pipe
Old May 25, 2007 | 03:30 PM
ORIGINAL: AteUrV8
Every gear
