Motor ticking
Old May 25, 2007 | 03:36 PM
techbod's Avatar
Default RE: Motor ticking
a test pipe is a mod and more noise will be heard so it might just be that ( tapping/pinking is hard to describe ) pinking only happens when the engine is under load so the problem could be fuel/air mix because the cat isn't there which is normal but better to use higher octane and see if it goes away and fit a K&N filter to equal it out
Old May 25, 2007 | 03:50 PM
sean1.8t's Avatar
ORIGINAL: avant80@2.6
dude, it's called Pinging, not "Pinking". but that is not his problem i can assure you.. might be that the cat was acting as a sound deadener for the turbo. now that that is gone you are just hearing more of what goes on. maybe the turbo is a bit on it's way out. not sure though without actually hearing the noise
Old May 25, 2007 | 03:53 PM
techbod's Avatar
its called pinking here dude
Old May 25, 2007 | 03:58 PM
sean1.8t's Avatar
well too bad, cause we're here
Old May 25, 2007 | 04:00 PM
techbod's Avatar
its a shame because your steering wheel is on the wrong side for startersand over here you would be considered mad for driving it
Old May 25, 2007 | 04:18 PM
techbod's Avatar
ORIGINAL: sean1.8t
Sean isn't that an Irish name cough
Old May 25, 2007 | 06:20 PM
sean1.8t's Avatar
oh yeah, well why don't you go buy some gas.. put a little dent your wallet eh? [8D]
Old May 25, 2007 | 08:23 PM
  #18
Quattro_1.8t's Avatar
Im pretty sure its not the turbo since the turbo is brand new, the CEL just came on so I will get the code ran, my guess is its the 02 sensor since i just got a test pipe on.
Old May 25, 2007 | 11:05 PM
  #19
Boostfed13's Avatar
Im runing an ATP test pipe on stock exhaust the sound you are hering is most likely an exhaust leak. Ijust went through the same thingI replacedtheexhaust clamps between the DP and mid pipe and mid pipe and resonater, there is no longer the ticking exhaust leak noise.
Old May 25, 2007 | 11:18 PM
  #20
96audia4's Avatar
ORIGINAL: Boostfed13
Yeah, I have a ticking noise under load that sounds like an exhaust leak to me. I also messed up the exhaust clamp after the downpipe (actually, it was my brother with a grinder). Didn't have much of a choice though...the testpipe install was a biatch.
