my $8 heat shield... lol
Old Sep 8, 2007 | 03:09 PM
  #21
fumoazul99's Avatar
Default RE: my $8 heat shield... lol
yah I seen that diy b4... but he doesn't specifically say how it sits at the bottom.... maybe it sits where the stock heatshield sits?
Old Sep 8, 2007 | 04:42 PM
  #22
fumoazul99's Avatar
does anyone know what the "screwdrivers" name is for the star looking bolts... and by any chance does any one know what sizes I would need
(im putting in an intake and im removing the airbox and stock heat shield)
will homedepot or lowes have them?
thanks
Old Sep 8, 2007 | 05:07 PM
  #23
new2me's Avatar
You can get hex bits in a little kit for a few bucks from Walmart, Home Depot, Menards.................... Dont know the size but a small 5-10 peice kit should do you just fine. (metric)
Old Sep 8, 2007 | 05:31 PM
  #24
cincyTT's Avatar
I'm make believe
you realize that regardless of the temp the filter sucks in, its still going to be X temp through the turbo due to turbo heat and being compressed and then cooled to X temp due to the intercooler right?
Old Sep 8, 2007 | 05:43 PM
  #25
onepoint8tee's Avatar
Random thought.... I wonder if I put a piece of foil in the oven between the burner and my chicken nuggets if they will get less cooked? I doubt it.
Old Sep 8, 2007 | 05:49 PM
  #26
cincyTT's Avatar
I'm make believe
no, butit will take far longer if you inclose it in the foil like he has done here. [8D]
Still not worth my $8, time, orunderhood appearence
Old Sep 8, 2007 | 08:48 PM
  #27
klum00's Avatar
the shield just sits on the frame of the car, once you get the stock air box out you'll see where it will sit. It's obviously not a seal, but the sheild definitely helps with the temp of the air on the filter side.
Old Sep 8, 2007 | 08:50 PM
  #28
cincyTT's Avatar
I'm make believe
ORIGINAL: klum00
again, you should read (if not reread) my first post in this thread.
Old Sep 8, 2007 | 08:53 PM
  #29
klum00's Avatar
ORIGINAL: cincyTT
This was for my 2.8 so don't have the turbo/ic to worry about
Old Sep 8, 2007 | 09:11 PM
  #30
cincyTT's Avatar
I'm make believe
Reading sigs help [:@]
In your case, the temp matters a TON
