My brake light is blinking and beeping.
Old Dec 1, 2006 | 10:28 PM
707782y's Avatar
Default My brake light is blinking and beeping.
Every morning when I turn on my car, drive it and make a right turn, my brake light would blink couple times and I could hear three beeps, this would happen couple times every time when I make a right turn, after that, the red light and the beeps would go away, what's the problem? Guys?
Note: My car are running normal and fine without any problems.
Old Dec 2, 2006 | 12:46 AM
turbo kraut's Avatar
Tech Guru
Default RE: My brake light is blinking and beeping.
checked your fluid?
checked your pads?
Old Dec 2, 2006 | 01:21 AM
veloracer's Avatar
Where's the sound coming from? The information display, dash, or the back shelf (3rd light)? Does this happen to you only in the morning when it's cold?
Old Dec 2, 2006 | 01:28 AM
WasWrxDriver's Avatar
if your brake light is coming on then it sounds like your pad indicators may be touching your rotor. have your brakes checked or look at them yourself. that or your brake fluid is low. this should be the problem same thing happened to me when it was time for new brake pads. your abs light isn't coming on is it?
Old Dec 2, 2006 | 02:22 AM
S_R_N83's Avatar
He said its a red light, so its not the pad indicator. Thats a yellow ((O))
I'd check fluid.
Old Dec 2, 2006 | 02:38 AM
oh yea your right
I'd check fluid.
Old Dec 2, 2006 | 02:39 AM
onepoint8tee's Avatar
ya- fluid.
Old Dec 2, 2006 | 05:40 PM
707782y's Avatar
To add the fluid, do you just remove the cap and pour more into it?
Old Dec 2, 2006 | 05:42 PM
707782y's Avatar
ORIGINAL: veloracer
Right where the right turn signal light is at, yes, it only happen in the moarning or afternoon when I first turn on the car and the first 30 minutes of drive or so.
cipi888
Jul 16, 2013 05:11 PM
a6xlr8s
Jan 4, 2013 01:32 PM
W99A428
Jun 24, 2010 03:10 PM
fidelite
Feb 3, 2009 11:04 PM
