My brakes go crazy!?!?!
Old May 1, 2006 | 06:56 AM
darchinova's Avatar
Default My brakes go crazy!?!?!
I was just waiting in my car with the engine on and foot to the brake as usual (my car is manual btw), then all of a sudden i get this shuddering feeling through the brake pedal!?! As if the brake pedal was moving in and out in quick succession.. like a vibration. This happened for about 2 seconds on a few occasions now. Luckily enough its only been when i'm standstill!
IS it a problem with my ecu or abs or soemthing? ANyone had this problem before?
Old May 1, 2006 | 07:13 AM
Trey25's Avatar
Default RE: My brakes go crazy!?!?!
I'm pretty sure its the ABS, at a standstill there shouldn't be any shuddering. That should only happen at moderate to high speeds or when you try to floor the pedal. Get it on a vagcom to find out whats going on.
Old May 1, 2006 | 07:52 AM
BadLuckAudi's Avatar
Its your ABS man, they will all do that if you press hard enough its normal
Old May 1, 2006 | 10:09 AM
JettaRed's Avatar
Did you ABS light come on? A common failure is the ABS controller. $750 for the repair.
Use a vag-com to check fault codes in the ABS controller module.
Old May 3, 2006 | 07:58 AM
darchinova's Avatar
ORIGINAL: BadLuckAudi
I just took it into service last week and no codes came up. I think your right about me pushing hard on the brakes to cause the shudder. thanks!
Old May 3, 2006 | 11:25 AM
north5995's Avatar
There has been like 3 posts on this forum in the last week about this same problem. Please search.
eos815
B7 Models
Jan 3, 2015 11:33 AM
Tripin
Feb 22, 2010 07:42 AM
311mofo
Jul 6, 2007 02:57 PM
AteUrV8
May 11, 2006 07:59 AM
PandaXpress
May 7, 2006 08:10 PM
