My car doesent Idle
Old Jan 22, 2007 | 01:37 AM
Aspec's Avatar
Member
Default My car doesent Idle
Hi ,
I got a 97 A4 2.8, I started my car at my friends house to warm it up, "15 degrees outside" and I went inside, I came out 10 min later and the car was off, I then started the engine only for it to shut down again. Started it one more time and it shut down again. Alright this is simple, the car wont idle, so I had to get it home to I blew through every stopsign and made it home, I couldnt hold the clutch in because the car would stall. The car runs fine when over idle but will stall out everytime i try to Idle the car. ..... Im Puzzled
Any ideas before i call the Audi Dealership for an appointment?
Old Jan 22, 2007 | 02:21 AM
01A4T's Avatar
Default RE: My car doesent Idle
check the TB(Throttle body) somthing could be wrong there............... or the MAF
Old Jan 22, 2007 | 02:35 AM
Aspec's Avatar
Member
Will do, Ill check all of that after work tommorow, wont be driving it.
Old Jan 23, 2007 | 01:02 AM
Aspec's Avatar
Member
Just to let you know the problem was a pin hole in a vacuum hose, or something like that, im not that technical but my dad came out and fixed it while i was at work. Hey its working and its great, Idles much better now than it ever did and it semes to have more power maybe its just the day. I donno...
Old Jan 23, 2007 | 02:48 AM
AteUrV8's Avatar
ORIGINAL: Aspec
if you plugged up a vacuum hose than you will definately have more power.
justinclarke
Nov 25, 2010 04:03 PM
Mean buzzen half dozen 08 A4
B7 Models
Jan 5, 2010 11:36 PM
TurboToughTT
Jul 6, 2007 11:07 PM
onepoint8tee
Dec 16, 2005 06:21 PM
