my cruise control works
Old Oct 6, 2007 | 09:58 PM
turbo kraut's Avatar
Tech Guru
Default my cruise control works
only at 61, 65, 71, and 82.........no other speeds, will have a video on my drive back from chitown to show you what i mean
but any explinations
Old Oct 6, 2007 | 10:10 PM
hiwords's Avatar
Default RE: my cruise control works
hmm. ur cruise control is messed up lol. thought i'd let u kno that lol j/k j/k. see if u can get a vag. maybe the module is bad or sm.
Old Oct 7, 2007 | 09:52 AM
Tech Guru
i looked under the dash and can't find a modual...... i was also told that an 01 doesn't have a modual....it is by vacum, can someone with an 01 a4 1.8t take a pic of their modual?
Old Oct 7, 2007 | 10:03 AM
A4 Effort's Avatar
Pfft - at least yours works (sorta). My cruise control has been MIA forover 2 years now.
Old Oct 7, 2007 | 10:31 AM
hiwords's Avatar
says in the haynes manual it's behind the the airbag unit on the passenger side. that's for mechanically controlled throttle. electronic controlled throttle is only the switch on the blinker. it's controlled by the fuel injection control module. wut engine code do u have?
Old Oct 7, 2007 | 02:39 PM
Tech Guru
awm
Old Oct 7, 2007 | 02:45 PM
khj677turbo's Avatar
you chipped?
Old Oct 7, 2007 | 08:19 PM
Tech Guru
yup, but that shouldn't matter, didn't work at all with my factory ecu, this is one a second one
Old Oct 8, 2007 | 01:31 AM
aikibil's Avatar
about six months ago my cruise started getting spotty. i drove 70mi each way interstate, and it would work and then, just cut out. sometimes it would work, others, not. local roads interstate, tried for weeks to get a pattern. a month later, i got the idea to change all my fuses (none blown, just did it). cruise has worked every time since. worth a shot.
AudiTurbo
Jan 13, 2011 05:52 PM
altonachrome
Apr 12, 2010 11:34 AM
chooch628
Sep 5, 2007 03:32 AM
A4 the Quattro
Mar 16, 2006 07:07 PM
