My First Upgrad
Old May 31, 2007 | 01:19 PM
jduplooy's Avatar
Default My First Upgrad
Ok, so I am looking at upgrading my 2000 Audi A4 1.8T. This will be my first upgrade and budget is somewhat tight. However I am willing to pay for something that is going to be worth the money. For a small initial upgrade, what do you guys think is the best thing to start with?? I hear all over the place that a chipped ECU, such as an APR chip is a good idea. Is there a better way to go for around the same cost?? And with an upgraded chip will I need to upgrade injectors, turbo, manifold?? Keep in mind that I will continue to upgrade, however I want to do it gradually as my finances permit. I guess just gimme some suggestions. Thanks in advance!
Old May 31, 2007 | 01:21 PM
Borden's Avatar
Default RE: My First Upgrad
no for the money the chip is the best upgrade
Old May 31, 2007 | 02:16 PM
akielb's Avatar
The question you need to ask is where you want to be not where do I start. once you know where you want to end up then you can start doing supporting mods and eventually reach your goal. Chip go with GIAC it will give you an upgrade route to the K04 turbo if you ever want to - APR doesn't have K04 software for the B5
Old May 31, 2007 | 02:53 PM
ironman's Avatar
Follow what akielb says thats exactly what you need to do.
Old May 31, 2007 | 03:37 PM
jduplooy's Avatar
Ok I will look into that chip. What kind of gains can I expect with just the chip upgrade, and then with the K04 turbo. Does the GIAC chip support BT turbos or anything else??
Old May 31, 2007 | 03:39 PM
Mya4T's Avatar
going to need a New DV before that chip stock one wont hold boost
tight on budget then get the TT vavlve if notthrow out the $140 and go forge 007
