My Review: GIAC Chip, N75h, 710N installed today!
Its been proven that reversing the dv does jack ****, its sorta a myth, lol and i have seen a bunch of 710n's eat **** reversed while oem way work forever
ITs #27 Lower pass side right at front.... you have to take tha plastic thing off and then its right there three clamps need to be cut off and replaced with new ones and your good to go
[IMG]local://upfiles/10526/7A6F8B1C8C1E46B299341FCDF804E046.gif[/IMG]
well the oem way it only holds up to 15psi ... but apparantly if you reverse it it can hold up to the 20 psi that i will be spking at..
i CAN VERIFY.. that it runs smoother.. a result of the reversing.. or by luck my ecu finally finished adapting to the chip directly after i reversed it..
i've read that if you DONT reverse it..that it will wear out super fast.. and you guys are saying that IF I DO reverse it .. then it will wear out fast? ...
ill have to wait and see i guess..
