N75 valve questions????
Old Dec 10, 2007 | 06:12 PM
drs305's Avatar
Member
Default N75 valve questions????
I found out that I had a bad N75 valve today after getting my ecu scanned. I want to know a good price for a stock replacement and if I should upgrade to the ECS N75 valve instead. My car has a GIAC chip and no other mods yet.
2001 A4 MAN FWD.
Old Dec 10, 2007 | 06:31 PM
onepoint8tee's Avatar
Default RE: N75 valve questions????
An N75 related fault code doesnt necessarily mean the n75 is bad. They hardly ever go bad. What is the fault code #?
Old Dec 10, 2007 | 06:41 PM
turbo kraut's Avatar
Tech Guru
but if you need one, i got a stocker....... 15+ shipping
Old Dec 10, 2007 | 07:30 PM
drs305's Avatar
Member
Here is what AWE Tuning report said:
1 Fault Found:
17956 - Boost Pressure Regulation Valve
(N75) : Open Circuit
P1548 - 35- -
They said to replace the N75 Valve and then to reset the ecu. They already reset it and I run around 13-15 boost now but, he said the error will likely come back untill the N75 is replaced.
Old Dec 10, 2007 | 07:57 PM
drs305's Avatar
Member
Is $89.75 a good price for the N75?
Here is the one I am looking at:
http://www.ecstuning.com/stage/n75-info.html
What do you think?
Old Dec 10, 2007 | 08:27 PM
Tech Guru
i thimk that is a good price as that is what i paid for mine, but my offer is still on the table, you could pay 15+ shipping for a good stock n75 or pay 85 for a race valve and that not be the problem
Old Dec 10, 2007 | 08:36 PM
drs305's Avatar
Member
Thanks for the offer but, i think I amgoing to go with the race N75 because I want to get the improved boost performance. Also, I am going to order the forge splitter at the same time I found it for $148.75. Here is the link:
http://www.esetuning.com/Forge-Motor...pltr-black.htm
Old Dec 10, 2007 | 10:17 PM
Tech Guru
np, man, just trying to help a brother out
Old Dec 11, 2007 | 09:19 AM
drs305's Avatar
Member
I just tried to order the n75 j from ecstuning and they will only sell the n75 f for 1.8t's. He said there is too many complications with the n75 j and h. Do you guys think I should go with the n75f?? Does anyone have a 01' 1.8t with a GIAC chip running a n75j?? Any problems?
Old Dec 11, 2007 | 09:22 AM
chaos92287's Avatar
never heard of the f. the h holds the most psi
here u go $69 - http://www.034motorsport.com/product...roducts_id=480
