n75valve, worth it?
Old Oct 26, 2007 | 07:56 PM
2000turbo's Avatar
Member
Default n75valve, worth it?
ok guys ive been readin on the n75 valves, mine is bad and i need to replace it,
is it worth to get? i heard that it could put the car into limp mode, and the boost comes too quick, is that true
if i get it wich one should i get the H or J, b/c every other post sais to get the other one
thanks for u help
Old Oct 26, 2007 | 08:00 PM
Bondga's Avatar
Default RE: n75valve, worth it?
I have a n75h for sale!!!! If your's is broke you deff need to replace it. as far as the j/h that depends. they work a little differently. the h makes the boost come a bit quicker and i don't remeber what the j does
Old Oct 26, 2007 | 08:07 PM
turbo kraut's Avatar
Tech Guru
i have an 01 awm motor and i have the race valve, i also have apr prog. and i have never gone limp with my valve
get your minds out of the gutter
Old Oct 26, 2007 | 08:12 PM
2000turbo's Avatar
Member
do u guys know any good sites were i can get them i tried ecs but they dont have it anymore
Old Oct 26, 2007 | 08:54 PM
cincyTT's Avatar
I'm make believe
n75's are about $60-75. I would just spend thatand a little more and get a turboXS hpbc and run w/o the n75. I never once have had a problem running it like this. Plus you can adjust the boost to what you want and not to mention faster spool and have the boost taper off slower so you have a longer powerband.
Old Oct 26, 2007 | 10:40 PM
Tech Guru
or you could buy a used n75, and plug it in(no hoses attached)and run the mbc with it, some run both the n75 pluged in(hoses attached)and a mbc
if you just wanna get a new/used n75, i would sell you my old one cheap
armyboy91083
Aug 7, 2010 01:48 AM
sa21189
Jun 19, 2010 04:01 PM
b5audi1.8t
Jan 30, 2009 01:54 AM
MEOONG
Feb 25, 2007 04:35 AM
EuroAudi
Jul 12, 2006 08:41 PM
