Need AC Clutch for a '96 A4 2.8L Quatro
Old Jun 18, 2007 | 01:32 PM
IvanKaramazov's Avatar
Default Need AC Clutch for a '96 A4 2.8L Quatro
My AC stopped working, and all signs point to a bad clutch coil (the system has plenty of pressure, and the clutch fails to engage even when I apply battery voltage directly to the wire leading to the AC clutch). Unfortunately, I can't find an AC coil or AC clutch for this car anywhere on the net (ebay, parts stores, whatever). I don't want to have to buy the whole damn compressor to fix this problem. Is it possible to buy just an AC clutch for this car (1996 A4 2.8L) anwywhere? Thanks.
Old Jun 18, 2007 | 01:37 PM
onepoint8tee's Avatar
Default RE: Need AC Clutch for a '96 A4 2.8L Quatro
I think you have to replace the whole compressor. Why wouldnt you want to do so on a 10 yr old+ car anyway?? Who knows how much longer it will last even with a new clutch in it???
http://getcoolparts.com/epcvsoapimc....d=getcoolparts
or
www.shokan.com
Old Jun 18, 2007 | 01:44 PM
techbod's Avatar
not my area and not sure you can buy the diode but worth a try
[IMG]local://upfiles/12092/E572A3248167487B96FDC7AF0E053C53.jpg[/IMG]
Old Jun 18, 2007 | 01:51 PM
^Thats not even a picture of an Audi! The compressor is on the opposite side of the engine and I dont even know if/where there is a diode to check??? Huh?
techbod's Avatar
how did you test the system pressure ( you need a gauge ) even though you might think the pressure is good it only has to drop to a certain pressure and the clutch wont cut in
Old Jun 18, 2007 | 01:54 PM
Used a gauge, and even had it professionaly tested. The pressure checks out.
TheDane
Mar 19, 2010 11:50 AM
rnbguy
Sep 10, 2009 12:47 AM
lex99frc
Sep 3, 2009 11:52 AM
kv
Feb 23, 2008 01:21 PM
