Clutch/Transmission: clutch master and slave cylinder have been replaced....
Old Aug 19, 2010 | 03:27 AM
ivanruiz817's Avatar
Default Clutch/Transmission: clutch master and slave cylinder have been replaced....
My clutch had no resistance so i could not shift so my car has been sitting for weeks. i managed to change the clutch master cylinder and also the slave cylinder but it continues to do the same thing... What would be the next move if changing those parts failed? And yes the system was bled.
Old Aug 19, 2010 | 09:37 PM
02A4kid's Avatar
your clutch is probably shot. or it may be a broken pressure plate
Old Aug 20, 2010 | 05:26 PM
Mike-2ptzero's Avatar
Could be a broken throw-out bearing or like someone else said a broken pressure plate.
Was it hard to put the new slave cylinder in?
Old Aug 21, 2010 | 04:37 AM
replacing it wasnt hard, its just tedious and it does require 2 people for the bleed at least... if you know a lil something about cars then you should be able to do it... how much do pressure plates run and the bearings as well if anyone knows?
Old Aug 21, 2010 | 10:22 AM
If the PP has to be replaced then its best to just buy a new clutch kit.
The reason I asked if it was hard to put the slave back in is if the PP or TB were broken the slave would be easier to put in.
Bleeding = 2 people or 1 person and a power bleeder.
Since you say the pedal has no resistance, does it at any point get very hard near the floor?
Old Sep 16, 2011 | 02:38 AM
pricenj's Avatar
I am having the same issue with mine. If I find out something i will let you know.
TeriWells
Oct 14, 2013 02:02 PM
JoeD1346
Apr 24, 2013 12:21 AM
I-Reef
Aug 15, 2012 01:28 PM
Mckayiva4
Sep 7, 2010 08:53 PM
