Need Audi expert
Old Dec 25, 2005 | 12:09 AM
silver_rings's Avatar
Default Need Audi expert
FIRST CODE:
Error code: (17511) O2 Sensor Heating Circ.,Bank1-Sensor1 Output too Low
I Changed both O2, Before and After Cat. O2 sensors because both looked jacked....
After replacing sensors, a few days later check engine light came bck on.
I checked if everything was connected correctly and tightned everything......few days later, Light check engine light came on again with same error......any ideas?
SECOND CODE:
Error code: 03167 CV-pump, alarm, RC D16, pump run exceeded, likely leak
Thanks All!
Old Dec 25, 2005 | 02:05 AM
jukeit's Avatar
Default RE: Need Audi expert
FYI - I'm not an Audi expert....but I do have the manual. I'm going to paste the procedures for troubleshooting the first code. Total of five pics. Had to split them up into 3 post due to file size. Did a search for the second code, but didn't turn up anything. If you end up following these procedures, I would appreciate it if you follow up and post results. Thanks and good luck.
[IMG]local://upfiles/6682/09392A7FDCD542E095C6AFEFBF301953.jpg[/IMG]
[IMG]local://upfiles/6682/93C3032C00D441B68D0EBE64886817BA.jpg[/IMG]
Old Dec 25, 2005 | 02:06 AM
jukeit's Avatar
Next pages....
[IMG]local://upfiles/6682/30B18D13EAE04C2D89F55C39A814FB2E.jpg[/IMG]
[IMG]local://upfiles/6682/8A77E01171064FF79B3E554B3B759AC4.jpg[/IMG]
Old Dec 25, 2005 | 02:07 AM
jukeit's Avatar
Hope you don't have to use this one.....replace ECM.
[IMG]local://upfiles/6682/2F282C56ED644344B765B449968F0DF9.jpg[/IMG]
Old Dec 25, 2005 | 02:22 AM
jukeit's Avatar
Just realized how crappy the text on those attachments is. You can make out most of it, but if you have questions just PM me about the specific section you are having problems reading.
BrianMFW
Jun 25, 2013 08:25 PM
Jaybreeze
B8 Models
Dec 6, 2011 08:28 PM
rusky325i
Nov 4, 2010 08:54 PM
dino123
Dec 13, 2009 07:29 PM
soaudi
Jun 1, 2007 11:28 PM
