Need to Find My ECU
Old Nov 18, 2005 | 07:58 PM
audispeeddemon's Avatar
Default Need to Find My ECU
i have a 1997 a4 1.8t and i am getting chipped tommorrow and i need to find the ecu number can u please help me thanks
Old Nov 18, 2005 | 08:41 PM
onepoint8tee's Avatar
Default RE: Need to Find My ECU
ORIGINAL: audispeeddemon
its in a caseing under the hood at the dirvers side corner under the plastic weather protector.
Old Nov 18, 2005 | 08:42 PM
Emil@RENN=ART's Avatar
If you know someone with a VAG COM you can read your ECU code from the OBD2 port. Otherwise you can physically read the number off the ECU, which is located on the driver side firewall, you'll have to pull back the weather strip and remove the plastic cover that runs under the wipers. It's in a weather sealed plastic box and to remove the cover you'll need to remove the 8mm screws first.
Old Nov 18, 2005 | 08:51 PM
thanks guys found it
mikees501
May 10, 2012 12:39 PM
b5audi1.8t
Apr 14, 2009 05:47 PM
auditurbo381
Sep 27, 2007 12:50 PM
Propagandalf
May 10, 2006 10:18 PM
