need good brake pads
Old Jul 31, 2007 | 08:07 AM
oettinger1919's Avatar
SoCal Crew Member
Default need good brake pads
Im upgrading the front rotors on my 98 quattro with some brembo drilled and slotted rotors and i still need a good recommendation for brake pads. I dont want to spend70 to a hundred on some ceramics so does anyone know of some good lower brake dust metallic pads?
Old Jul 31, 2007 | 09:52 AM
kraylon's Avatar
Default RE: need good brake pads
i got the ebc red stuff with ecs slotted and cross drilled rotors stops on a dime if those are out of your price range i suggest the ebc ulitmax pads i installed them on my moms 97 camry that has cross drilled rotors (she does alot of mountain driving) and they work great and i think they where less then 50 foe the camry. here are some good places to check
http://autopartswarehouse.com
http://ajusa.com
Old Jul 31, 2007 | 10:21 AM
dafrazi's Avatar
I would reccomend that you spend the money on good pads and buy cheaper rotors. Not expensive rotors and cheap pads.
Low dust and inexpensive are almost mutually exclusive. You can get the pads wiithout the brake wear sensor and use them to save a few bucks (~$15-$20). You will just need to splice the sensor wire together tokeep the brake light from coming on.
Old Jul 31, 2007 | 10:30 AM
wood_e's Avatar
EBC greenstuff are nice pads. I buy the cheapest rotors i can - they work just fine. I have an extra set of front greenstuff pads that I don't need. PM me if you'd like them... I'll let them go for $45 shipped - they don't have the pad wear sensors
Old Jul 31, 2007 | 11:04 AM
hiwords's Avatar
i think if ur gonna go for good ones get all good ones. i wouldnt' get good pads and bad rotors or vice versa. even though it cost more, it'll be worth it. also see if u can get the pads at a local store with lifetime warranty on them.
Old Jul 31, 2007 | 06:52 PM
Bendet's Avatar
+1 for EBC greenstuff, great bite, the new rims are happy with low brake dust and they're not too expensive
Old Jul 31, 2007 | 07:05 PM
wood_e's Avatar
ORIGINAL: hiwords
A blank rotor is a blank rotor from whoever you get it from - They're all manufactured to OEM specs.
jinsojoo
Sep 16, 2021 04:49 PM
speedracr226
Aug 5, 2009 05:07 PM
mra
Oct 23, 2007 05:03 PM
black b5
Jun 1, 2005 09:36 PM
