need help please won't start a4 2001
Old Jul 2, 2007 | 02:18 PM
sludgpump's Avatar
Default need help please won't start a4 2001
if some one out there can give me a hand it would be greatly appr.
last month the check oil light flashed on my 2001 a41.8t awm motor while i was on the highway .So i made it to the next exit checked the oil ,it was low 1/2 liter,got back in light was out so i continued drving home .so by the time igot home the light was on constantly turned thecar off and parked it 4 about a week or so .checked oil pressure ,there was nothing .i change the oil pump and cleaned the oil sump,it was blocked .fig. that that was it, get in and start .nope car won't start anymore.wiered didn't have any probs before,accept for low oil light .well when motor is dry(not started for a while,not flooded) i get a 1 second start then stall, plugs very wet.checked quite abit of stuff ,fuel press 50lbs steady thought it might be fuel reg but while cranking fuel varies from 48 to 55lbs checked timing belt ,checked for turbo binding found it was ,removed it and re torqued the impeller shaft, bolt it was loose.oil press while cranking is about 17 to 20 lbs .changed the plugs ,unplugged maf checked for vacume leaks didn't find any,still the same checked compression no.1 125 no.2 100 no.3 100no.4 115is it too low to start the motor?checked for codes with snap on generic obd 11 for audi no codes.disconnected the batt. to lose all addaptations to see if it would change any thing,nope same thing 1sec.start then stall ,flooded plugs .checked comp. again ,dropped because of cylinder washout.i also removed the cams to check the lifters and did find a few stuck.unstuckthem reinstalled the cams the right wayof coarse 16 teeth apart they were also marked.filled the crank case up with diesel let it sit overnight. emptied it ,filled it with new oil and filter mobile1syn 10w30.still the same any ideas guys thanks.ps don't have a vag com would like to have one though,i don't know where to get one.or how much theycost.
Old Jul 2, 2007 | 02:42 PM
auditech79's Avatar
Default RE: need help please won't start a4 2001
Thanks for giving a good description. My guess is you f****d up something when either installing the oil pump or the chain on the oil pump fell off. Did you try checking the oil pressure while cranking the engine after your repair? If the oil pump is completely blocked and the oil pressure is less than 5 psi the engine management will shut the engine off.
Old Jul 2, 2007 | 02:49 PM
david9999's Avatar
Sounds like you know what you are doing. Find someone with a vagcom using the vagcom locator and try to get the codes read.
Old Jul 2, 2007 | 05:23 PM
sludgpump's Avatar
yes at first the oil press was allmost 0 after i changed the oil pump the press was 18 to 20 lbs the chain is fine i removed the pan to recheck .once the engine managment shuts the engine down do i have to readapt the ecm or do a basic setting before it will restart?
Old Jul 2, 2007 | 05:29 PM
auditech79's Avatar
18-20 psi? Thats not nearly enough, it should be somewhere around 4bar or 60psi minimum.
Check the fault codes for possibly anything thats causing the engine to shut down using a VAG COM or factory scanner, a cheap OBD scanner won't read stored or static faults.
You replaced the oil pick up tube right? Thats the main problem, you can't just clean it out.
Old Jul 2, 2007 | 05:31 PM
sludgpump's Avatar
would a vag com see something that the generic obd2 wouldn't and if i buy a usb to obd interface cable from fleabay with the vag com prog would it work?
Old Jul 2, 2007 | 05:34 PM
sludgpump's Avatar
no didnt change the tube by the time i cleaned it blew air through it thought it would be clean enough.
Old Jul 2, 2007 | 05:38 PM
sludgpump's Avatar
60 psi when the car starts or cranking?
Old Jul 2, 2007 | 05:40 PM
auditech79's Avatar
I don't care if you can get air through the pick up tube or not, it has to be replaced trust me.
As for the VAG COM there are different cables for different programmes, check out www.ross-tech.com and you'll see what im talking about.
Some people buy cables off of e-bay and have had problems with communication with the car, it should work but the cable is well worth buying off of ross tech.
Old Jul 2, 2007 | 05:42 PM
auditech79's Avatar
Cranking should be almost the same as the engine running, nothing lower than 40 psi while cranking is acceptable.
