Sponsored by:
Sponsored by:
Need Help With Shifter!! Please Someone Help, I can't drive!!
Old 04-24-2007, 06:06 AM
Chunkle's Avatar
Default Need Help With Shifter!! Please Someone Help, I can't drive!!
Ok one day I am driving and i shift out of gear i hear a spring pop, all of a sudden I can't shift into my gears easily I have to jam it I get in 1st then 2nd then 3rd. I opened it up and did a transplant got a whole new assembly, new shifter everything. I still have the same problem i go into 1st 2nd 3rd then 4th non existant, i cant reverse. When this problem firstoccured I could go into reverse and everything it was just really tough. Now what should I do? Do I need to replace the linkage as well? The transmission works fine. Please someone help me out I have been stranded some days now.
Old 04-24-2007, 07:49 AM
kraylon's Avatar
Default RE: Need Help With Shifter!! Please Someone Help, I can't drive!!
check to see if the linkage is jamed up or bent you will need to jack the car up and crawl under it to see the linkage
Old 04-24-2007, 10:41 AM
Amze's Avatar
Sounds like you might wanna take the shift cover off and have a look underneath where the magic happens, something went wrong clearly... Is it possible to have someone whos "Carsmart" take a quick loot at the car even though you can't bring it to them... if so. Do that.
kbevere
10-14-2010 09:36 AM
jibberjive
02-24-2009 12:57 AM
jibberjive
01-09-2009 09:16 AM
jlinaschke
02-09-2007 10:17 PM
sandnsnow24
02-15-2006 02:26 AM
Quick Reply: Need Help With Shifter!! Please Someone Help, I can't drive!!
