Need a quick simple answer.
Old Jun 4, 2006 | 02:29 AM
a4sport's Avatar
Default Need a quick simple answer.
Since I'm very new to Audi's, there is no particular way to jack up my b6 right? Just throw the jack under and go up with it? I need to change my oil and wanted to make absolutely sure before I started raising her up.
Old Jun 4, 2006 | 03:05 AM
Trey25's Avatar
Default RE: Need a quick simple answer.
Don't you have a manual??? Well I don't know about the b6 but on the b5 the lifting points are indicated by diamond indentations on the lower molding. I'm guessing a b6 would have this too. Its a b5 but this might help you out, check out the pics... https://www.audiforums.com/m_15746/tm.htm And don't use the pathetic jack thats in the car.
Old Jun 4, 2006 | 06:01 AM
dan908's Avatar
My A6 manual tells me the points to jack from and has a little slot to plug the crap jack into, ahead of the rear tires and behind the fronts. The idiot who owned it before me jacked it between the two jack points and there is a dent in the floor right there.
Old Jun 4, 2006 | 06:06 AM
Dj Spiel's Avatar
Follow there instructions....
Get a cover or box or sumthing. Get underneath your car look for the lifting points. You really should only place the jack there. I have put it under other points on my car. Although, I dont reccomend this.
If you dont need to get that high. Use the AUDI JACK TOOL. And get 2 jack stands.
ORIGINAL: a4sport
Old Jun 4, 2006 | 10:49 AM
david9999's Avatar
Well, the first thing to know is that you NEVER GET UNDER A CAR THAT IS SUPPORTED BY A JACK.
Get a set of wheel ramps or jack stands. Make sure tha car is stable on the jack stands or wheel ramps, and the rear wheels are chocked both in front and behind.
Old Jun 4, 2006 | 01:00 PM
a4sport's Avatar
Thanks guys. Figured it had points on it for jacking. Just wanted to make sure there wasn't anything electronic that I would mess up. I don't know. I hope I can get it done today.
zccjdm
Sep 21, 2012 11:54 AM
rdltmc3
Dec 21, 2011 10:54 AM
Jokershockey29
Jun 12, 2011 10:32 PM
jrmdir
May 1, 2008 12:44 PM
scosta
Aug 2, 2006 02:55 AM
