Need some advice fuel & fmic
I have a 01 A4 1.8 T 105K miles.Well my gas tank is leaking when I fill it up all the way and it's giving me a cel (sucks only boosting 5psi max). I searched this forum for about 2 hours and I was not able to find anything to help me out. I read that it's very common for it to leak. I guess there is some kind of metal fitting at the top that rusts away and makes it leak. I guess you have to drop the axels to get the tank out.I seen that mosty people took it to the dealership and got it fixed for about 3k. Does the whole tank needreplaced eventhough it's just the top fitting.Really don't want to spend that much money to fix that (I could think of many other ways to spend that kind of money). Has anyone come up with any other solutions. Also I was hoping to get this fixed and try to do some modding to my car. I was looking to get a fmic. Can I run a fmic on a stock turbo. Is it good or bad. Anyone have any advice on where to buy one. Are the ones on ebay junk. Any advice would be great. Thanks.
I can't help you with the fuel leak - I haven't had to deal with that. However, you can use the FMIC on stock boost. It may not give you any gains (I'm not sure), but if you're going to be modding and will eventually need more intercooling, I doubt it will hurt. Here's the DIY article from the DIY forum:
https://www.audiforums.com/m.asp?m=382435
Even the fmic's that ebay sells have proven to work as well as the one's from major suppliers that can cost 10 times as much. They really arent a complicated design, and the materials arent exotic or anything. Ill never understand how most places can charge $900+ for these things.
ORIGINAL: onepoint8tee
so if you have a ko3/4 and some fab skills, a ebay core is great and can be done very cheapy and effectively. Then you can just splerge on a garrett/pte core when you go larger if you do.
Makes sense. Thanks for all your wisodom TT.
Research and design is a little over rated when it comes to some things though. Still not worth $900+ imo. A test pipe isaprimeexample of how R&D is over rated. $150 (at least) for a pipe with a bend and a couple flanges that is actually worth maybe $20-$30 in materials at most.
You should go read Kakrot's BS he is spuwing in the turbo/supercharger section. All i can say is engineer wanna-a-be's are funny, yet annoying. And how the hell did he get a Tech Cert tag? The kids a moron
