need some help
Old Jul 29, 2005 | 05:28 PM
hb972.8q's Avatar
Default need some help
i was doing my A8 brake upgrade and noticed this. this (steering?) part on the passenger side in the pic was loose and wobbled a bit side to side in a clock wise maner. the pic is from the drivers side forgot to take a pic of it.
[IMG][/IMG]
[IMG][/IMG]
what part is this
should i be worried
anything i can do the bolts seem tight
also where can i get not to expensive but decent upgraded brake lines my oem ones are fraied
thanks
Old Jul 29, 2005 | 08:19 PM
audilover04's Avatar
Default RE: need some help
Cant help you on that one why dont u try posting in the forum for A8's or take it to the dealer and ask them.
Old Jul 29, 2005 | 11:06 PM
david9999's Avatar
That is a tie rod end. It needs to be replaced. There is an upgraded heavy duty part made and available at ECS.
Symptoms are a "clunk" if you go slowly over curbs or bumps, and poor steering response. It needs to be fixed. If you are having control arm issues (eg squeeks, you might as well replace them at the same time.
Old Jul 30, 2005 | 11:35 AM
hb972.8q's Avatar
audilover04.... i have an a4. i just upgraded my brakes they consist of tt calipers brackets and A8 rotors.
david9999....i have the ecs upgrade kit with heavy duty tie rod ends. they were installed prob less than a year ago. i have no symtoms like you discribed i know th failing controlarm squeek/clunk very well. it was just a little loose
anyone else??
