need some help bad!!
Old May 11, 2006 | 11:27 PM
germancarmaniac's Avatar
Default need some help bad!!
alright, heres the deal. A few months ago i tested my turbo system for leaks and found none. I adjusted the bypass valve(turboxs) and my car ran like new. It was amazing! Although i noticed that the turbo sounded like it was leaking. Thought nothing else about it and went on because the boost gauge was reading 15-16 psi. I have now swicthed to a forge 007 and my car has continued to run well. Now, the fun part where all you mechanics come into play. I just got done drilling my spark plug non-fouler(sp) because im going to put a test pipe on this weekend. I go out to my car and pop my hood to see if there is enough room for the foulers(sp). While im looking around i notice that the hose from my wastegate to the n75 valve has come off( im asuming i forgot to hook it back up, hints the leak sound,while i tested the system a number of months back). So i said cool, my car should run better now. WRONG!!! i got in and drove it up the street and was only getting 11 psi. 11 FU*KING PSI. What should i do? take the hose back off or keep it on? thanks guys, i know someone on this site will steer me in the right direction.
PS 99.5 1.8t quattro (apr chip,forge 007)
Old May 11, 2006 | 11:32 PM
wolfy_hockey88's Avatar
Default RE: need some help bad!!
maybe your dv is on the wrong way, try switching it back around
Old May 11, 2006 | 11:33 PM
ok. ill try that. anything else?
Old May 11, 2006 | 11:35 PM
isnt the side piece supposed to go to the air box though?
Old May 11, 2006 | 11:38 PM
boost should come in from the bottom and out the side
Old May 11, 2006 | 11:39 PM
exactly, so the bottom should be on the intercooler piping.
Old May 11, 2006 | 11:43 PM
yeah, other than that i have no idea, there could be a boost leak somewhere else, not sure if maybe the spring on the dv is loose and is leaking boost into the intake
Old May 11, 2006 | 11:47 PM
but that wouldnt change the reading im getting on the boost gauge would it? i would still be getting 16 psi right? Would it hurt if i left it off? it runs so much better.
Old May 11, 2006 | 11:53 PM
you could leave it off it doesnt show a cel and the car runs fine, just get a plug for the hose, you can get those from ecodetuning.com i think
Old May 12, 2006 | 12:00 AM
i dont know though, i think you should find the real problem, cause it could be a lot worse and it might get expensive if you dont fix it, but you said the car SOUNDED or FELT like it was leaking boost, cause if the hose is off, it will basicly run like a BOV
