Need some help with my audi a4
Old Jan 10, 2008 | 12:59 AM
Jambre Deux's Avatar
Default Need some help with my audi a4
My 1998 Audi A4 Quattro, turbo charged, smells like exhuast/gas in the cab. my brother and i found a plastic pipe broken and i would like to know what part it is, and how to change it. any help would be greatly appreciated, i'm going to try to load some pictures up of where it is. the red is the cracked part and the yellowis where itleads to with a hosethat comes off of it. my brohersaid ithassomething to do with the vacuum or fuel injection.thanks.
[IMG]local://upfiles/46532/398249F5CDBF45BEA28EEBE246834A13.jpg[/IMG]
[IMG]local://upfiles/46532/31D32421393D4DEAB70AABAB82D86D1A.jpg[/IMG]
Old Jan 10, 2008 | 01:41 AM
Steel02001's Avatar
Default RE: Need some help with my audi a4
I really dont think this will effect your exhaust in the cab smell. Maybe its just me but the hole seems to smell to make the hole cab consistently smell of exhaust fumes. Have you had any exhaust work done recently at all? There are gaskets that could have been left off that are leading to leaks or you could simply have a hole in the exhaust somewhere. It is possible that hose will fix your problem but I doubt it
Old Jan 10, 2008 | 10:45 PM
Well it's usually just when i come to a stop, i don't smell it when i'm driving but when i stop it comes out of the vents, it smells really bad right there also if i open my engine up.
Old Jan 10, 2008 | 10:50 PM
Steel02001's Avatar
I was thinking it was more of a permeating lingering smell.
It could definitely be that leak, I am curious to see how things turn out.
Old Jan 11, 2008 | 06:34 PM
CoastalA4's Avatar
I believe that's your PCV piping. They'll deteriorate from the heat and breakdown. Crankcase vapors are probably being sucked up into your cowl vent and into the cabin. You probably need to replace that for more than just your health. There's the possibility of blowby gases building up in your engine.
