Never understood this.
Old Jun 30, 2006 | 12:09 AM
a4sport's Avatar
Default Never understood this.
Maybe I'm totally wrong, but I never understood why the codes that an Audi gets has so many things that need to be checked.
Like this one:
P1136
17544
Long Term Fuel Trim Add. Fuel, Bank1
System too Lean -
Check intake air system for leaks ("false air") Page 24-97
- Check Mass Air Flow (MAF) sensor -G70- Page 24-57
- Check fuel pressure regulator and residual fuel pressure Page 24-93
- Check fuel injectors
Why can't it just be a single thing to check. Just seems like it's too difficult to figure out sometimes. This isn't my code, thankfully I don't have any, but if I ever get one I'm going to be pissed. I wouldn't want to have to check all that stuff for a fix. Just don't get it.
Old Jun 30, 2006 | 12:14 AM
Trey25's Avatar
Default RE: Never understood this.
Because like any other car it could be a variety of things that will give the same symptom. They're just trying to cover all the bases and taking the guess work out of diagnostics.
Old Jun 30, 2006 | 12:19 AM
a4sport's Avatar
I thought on a normal car, it just said what it was. On my Integra, if I ever threw a code, it told me what it was specifically.
Old Jun 30, 2006 | 12:45 AM
wood_e's Avatar
In my experience Audi/VW computers monitor a LOT more things than a "normal car"
Old Jun 30, 2006 | 01:13 AM
david9999's Avatar
Those are all the things that can cause a lean condition.
same thing on your acura. I just decoded all the things that can cause a lean condition...
Vacuum leak, ECU getting a signal that not enough air is going into the engine (BAD MAF), or not enough fuel (clogged injector or not enough fuel pressure).
Old Jun 30, 2006 | 02:04 AM
a4sport's Avatar
So, them most of the time there is only a certain description for the code and then you have to figure it out from there.
Old Jun 30, 2006 | 02:30 AM
wood_e's Avatar
uh, yeah man. I had a lean code on my Taurus Sho with new 02 sensors...
long story short, the O2s werte reading improperly...
Old Jun 30, 2006 | 05:38 AM
toyolla86's Avatar
fukc the codes i just start messing with **** till that check engine light is gone. hahaha
a little unorthodox but hasnt failed me yet.
Old Jun 30, 2006 | 11:31 AM
tatman9999's Avatar
Replace the mass air low sensor.80% of the time that what it is .the other 20% is air leak or 02 sensor
Old Jun 30, 2006 | 02:14 PM
techbod's Avatar
o2 sensor is the first mistake you will make because it was an air leak so the o2 sensor detected it and threw the code (air leak caused the problem) o2 sensor was doing its job, the codes are a guide and have to be read like a book im given 3 to 5 choices to check out, if you only know the code you only have one choice through lack of knowledge which is why I can look for possibilities and you cant (im trained to do this)
